1 - 20 of 27 Posts
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
So it's still a little early for a build thread. As I've only collected the parts so far and haven't actually started the build yet. Well I have in my mind but no machining yet.
I'll be adding lots to this thread in the next few weeks. I hope to get a atleast one big item done every Saturday. And get smaller things done on my lunch breaks and after work.
Today I'll have pics of a z6 head cut in half so I can measure the port wall thickness. Seems k20 ports won't fit due to oil passages, i dont give a shit about coolant passages they can be welded.
Here is a my personal list of things to do before assembly. It's not complete and was ment to serve as a reminder of what's left. So it doesn't exaplne everything very well. But by reading it you will understand enough to see where this is going.
I always like doing things to the max. I'm quite well known by this quote and it's been said about me countless times (Evan only goes big or goes home, and he's already home, sooo)
I'll be burning Q16 in it.
I don't care if the motor only lasts for a few hours run time. I'm shooting for 240whp on a dyno jet. Or break 200 on a mustang dyno.
I want to beat bisimotos d16 builds HP is my only goal right now.
This whole thing is open for discussion and critisisym
But while your thinking the stoke is too long and the rods are too short. Look up 4pistons NA k24 500hp. They stroked the motor to uses a 1.47:1 rod to stroke ratio. So I'll have the same RtS ratio. my stoke is less won't be revving as high
Here is the list
BLOCK-*
D16A6 block
CSS installed first
block sleeved custom sleeves
bored and hone to 81.5mm with bore spacing changed to 86mm from 84mm
decked 0.005
block and girtle notched for rods
CRANK, RODS and PISTONS-
D17 crank with rod journls widened +2mm for d16 rods
rod journals machined on left or right side to make 86mm bore spacing
knife edged and ballanced crank
D16 forged rods with arp2000's
rod small end reamed to 21mm from OEM 19mm. -1mm off center. 136mm length rod
B series 81.5mm pistons -3 to -12cc dish
0.050 turned off the face of the piston to make 28.8mm comp height
HEAD-
d16z6 head
milled 0.100" 26CC combustion chambers
compustion chambers bored out to 79mm bore, deshrouding the valves
cumbustion chambers moved to be on 86mm bore center
+1mm ferrea 6000 valves IN/EX
new C63000 valve seats made for +1mm valves, 5 angle with custom depth.
Bisi LVL3 cam sent for regrind
bisi valve springs
supertech TI retainers
Massive port work on both Intake and Exaust sides
INTAKE, FUEL-
48MM itbs attached to my custom flange plate and 6" tapered runners
New 255 walbro fuel pump
Q16 Leaded
EXAUST-
custom header and exaust
ELECTRONICS-
BOLT ONs-
SPECS
81mmx94.4mm bore and stroke
1970CC
15:1 comp
You know, That's actually an awesome idea man.
I'm probably going to do that now that you mention it.
I just already own the valve springs and cam is why I was planning on using them. That will save 650usd and for me in Canada that's over 850$can.
But I agree beating his numbers without his parts would be a better thing to do. So I'm going to do just that
Also here are pics of a Z6 head cut up. Damned oil gally only 3mm into the roof of 2 of the ports. So I'll be going quite a bit wider in the ports then taller.
Discussion Starter · #5 ·
Yeah for sure man..think of stuff to say. I love talking about this stuff and bouncing ideas off others.
Also that head didn't have a matching rocker assembly. It had no tec rockers in it when I took the valve cover off amd one cam journal pretty scored up.
08 H-D Ultra Classic
sounds like it will be dope.
my only thought is find different cam and springs. show bisi we dont need his parts to make more power than him lol.
First thought also why try to beat someone with their own parts.
Sub'd
Reactions: civicdxude
Discussion Starter · #7 · (Edited)
^^ Yes if I didn't already own the cam and valve springs i never would have done it. I owned the cam and springs since 2011.
Well my custom sleeves made it to my work today. Now to finish them. 45-65-12 ductile iron. I'll harden them after I machine them to 40RC. Should be around 130,000psi
Also there is one.more shot of the head ports. I could only fit 5 in the last thread
EDIT;
you can also see the 79mm scribe line for the new combustion chamber size, that head is also milled 0.130" its a z6 head but as you can see the valve seats are cutting into the flat of the head. the valves will be deshoruded by the time they start to open. if you look at a Yamaha R6 combustion chamber (see added pic) you will see what im going for in the combustion chamber. and the there isnt much room between the chamber and the water ports in the head for an O ring, so ill be welding them up and moving them out 5mm from where they are.
im trying everything on this head to make sure i dont run into problems before doing it on the head im using.
Discussion Starter · #9 · (Edited)
It sends oil from the block to vtec solenoid
On the roof of the intake port just after the injector spray cutout it is only 3.4mm ( 0.140") it only effects 2 cylinders.
In this pics. I have it labeled
Take something like a can of paint and mark them or tap them with a die grinder somewhere that wont effect anything or something and say they are bisi modified lol
BTW Cutaways look good I like seeing stuff like this.
B-series Destroyer
4g 4d civic
I like it!!!!
Reactions: Evanguy
MuthaFuckaUppa
2009 Civic Si Sedan
Interesting, changing the bore spacing.
What about a small V like a VW VR6. Pocket rocket allegedly did this to the H-series to make large displacement engines.
Discussion Starter · #15 · (Edited)
does getting the cam reground by someone else count as that? also im sure i have other valve springs sitting around i can use.
i figure changing the bore spacing will be the simplest way for me to run 81.5mm pistons and still have 4.5mm between (b20 with 86mm bore has less)
the middle two cylinders are only 1mm over and the outers are 3mm, so the combustion chambers still line up,
using the d16 rods on the d17 crank it turns out i dont have to machine the rod journals on the crank. i just have to machine one side of the outer rods making them 3mm narrower to fit the d17 crank and the inner rods ill take 1mm off a side and 2mm off the other making them fit the d17 crank
and then run d17 rod bearings and ill have to recut the rod tang spots in the rod caps to have the bearing sit centered
so really to do this im just sleeving the block on a 86mm bore center opposed to a 84mm, so no real difference there, the head is an easy fix, only have to do anything on the outer 2 chambers and then machine the rods one side or the other to move their centers where i need them then machine new rod bearing tang cutouts
also so im going to knife edge the crank this Saturday and send it for balancing, but while i was looking at a few different cranks i noticed that my d13 crank was missing some counter weights from factory, interesting, and it just so happens that the counter weights on a d16/17 crank there are two different thickness of counter weights. the thin counter weights are the ones missing on the d13 crank
Interesting fact. The d13 crank uses the same size crank stub is the d17 crank. As you can see in the pic I added.
Discussion Starter · #17 ·
Yeah too set the crank up and dial it in, in two 4 jaw chucks ( one on the head stock and one on the tail stock) to matching 3mm out of the rod journals woud have taken probably 8 hours. To get all four done.
Machining the rods makes it way easier for sure.
Also I got the d13 crank from India. A member here 007 shipped it to me. I wanted to use it to build a project that hasn't started yet.
cool! a big block D! I just signed in here after being absent forever and was expecting it to be deader than all hell, I'm glad to see people are still working on these things. :)
Discussion Starter · #20 ·
Well i have no idea how to do anything on here any more lol. Nor sure how to upload pics..i hope its easier on my computer. But on my phone i cant seem to figure it out.
Anyway. I got some more work done on this. Its slowly moving along. With winter coming it should start to move faster.
I have my rods machined. The small end is opened up for bseries wrist pin and the sides are milled to fit them on the D17 crank. They will milled to off set them due to the bore spacing being different.
The rods needed 3mm off them to fit the d17 crank and it works out that is exactly how much i need rod 1 and 4 offset. Rods 2 and 3 only needed to be offset 1mm each. Since im.working from the center line out.
I have my valve seats done. They are made of C63000 ni-alu-bronze.
The valve seats are made for me to use +2mm intake and +1mm exaust valves.
I plan on running ferrea super alloy exaust valves and supertech SS black nitrate intakes (ferrea doesnt make +2 intakes)
Sleeves are being machined as i type this. I need to rought them out, harden them and then finish machining after.
I hope to get working on the block here soon. I realized ill have to weld up the sided of the.block..by the tensioner pully mount and also the same spot on the other end. As the wider bore spacing and also the sleeves thickness will have them poking out of the block slightly.
Ill figure out how to post pics after i post this.
1 - 20 of 27 Posts
