Hello I was just curious if anyone had the wiring diagram for the pgm fi harness that the relays plug into. I am main focused on the relay that deals with the crank sensor. I have a 12 Volt constant white/black wire feeding power to the relay coil and I have a white/black 12 Volt constant that I believe should go to the 30 pin on the relay just trying to make sure the wiring is correct... Thanks
