Howdy I may be new hear but im not new to the D. I need help with my newly aqquired d17 i want to run it in a 98 ej8 but, the reson i aquired this motor was it has a blown rod. It is my understanding that th y8 rotating assembly will fit in and so will the cam. but if i run the y8 cam and dizzy can I run the y8 ecu? or would if I have to get a haltech or hondata? also what parts easily swap from the y8 into the a2? thanks for the help.
Very few things swap from the y8 to the d17. While it is possible, and it has been argued many times, it isn't practical at all. The d17 is a coil on plug motor, no dizzy. I don't believe the y8 rotating assembly will go into a d17 block. The d17 rotating assembly will go into the y8 though. As for your actual swap, I would try and ditch the d17 and find a y8 or something. It will be much simpler that way.
98 Civic EX
^^agreed...the d17 motor, while an ok one, not the best platform for the 6th gen civic, stick with the y8 or z6...
68 Camaro
not to mention the that d16 and d15s respond much better to bolt ons. i would sell it and buy a y7 or y8
1966 Volvo
^ I hate that statement. Not trying to bust your balls, but a D17 responds just as well to bolt-ons as any other SOHC Honda motor - in otherwords hardly at all. I/H/E will yield just as much power on a 7th gen as a 6th gen. It's the whole OBD thing that you guys have on us and the ability to run chipped ECUs.
agreed the only reason you may and i say may see more gains in any sohc honda is cause the d17 ecu will tune itself around the mods for fuel economie with proper tuning it responds as well or better than the other d series and bud go for a z6 or y8 d17 in my experience are just pure garbage they dont last but not my prob anymore i bought a 09 ss\tc :D
92 4dr EG
i made my search and with a y8 and d17 and sleeves a d18y8 is possible
when your shit is money up to atleast 5k if you go cheap
(d17 crank wit notch to the block to mate y8 motor d17crank custom rods'piston'sleeves oil pump adaptation bigger water pump ecu mods and datalogin 4 reliability no head work )
sql civic has done 1 na style 150hp lot ov torque real nice motor
Engine:
D16Y8 1801cc displacement
78 mm bored Darton MID open deck sleeves
D17 crank
Custom Arias pistons 10.2:1 C/R
Crower maxi lite rods
ACL bearings
Toga HV oil pump
Blox TPS
AEM adj cam gear
AEM fuel rail
Aeromotive FPR
Marshall fuel pressure gauge
Y8 Head/IM/TB/Injectors
Hondata thermal IM gasket
DIY Mild PnP
ARP Head Studs
Royal Purple 5w30
Moroso strut bar
Moroso clear blue dizzy cap
NGK High Performance Hyper Silicone Power Cables
SCO J's Racing Style air intake
Blue Samco coolant hoses
4 gauge ground wires
Kamikaze header
Vibrant Universal Metal Core Race Converter (578 CFM)
RS*R ExMag CatBack exhaust
Innovative engine mounts (street)
Spoon reservoir covers
Drivetrain:
EX tranny
Quaife LSD
Competition Clutch Stage 2 clutch
Competition Clutch 12lb flywheel
Pennzoil Syncromesh
Black SS clutch cable
EMS:
Boomslang ODBIIa->ODBI harness
P28 Hondata S300
PLX DM-5 AFR WB O2 sensor
