1 - 12 of 12 Posts
I like change the pinston, I need elevate the compresion. My compresion is 9.5:1 in my D17a1
this piston Wiseco Piston Kit-Civic 01-05 SOHC D17 (75.5mm Bore/8.8:1 Compression ratio) ??? elevate the compresion?
9.5:1 + 8.8.1 = ??
Post...
I dont like turbo....
OEM Honda piston - PMS-A00
From 01-03 Honda Civic GX (Natural Gas)
12.5:1 compression.
9.5:1 + 8.8.1 = ??
Post...
HOLY HELL!!! What? You want some new pistons to bump your compression up? Go with this dude vvvvv Just get a good tune to avoid pinging.
12.5:1 compression.
You could just mill he head slightly lol.... but are your trying to build an NA D17 Motor or what? LMAO if you are lol. You will be looking at about 180hp max with intake, new pistons and rods, exhaust, stage 3 cam, Hondata k-pro, and cam gear. That motor just isnt a great motor. unless you boost
180 hp on a d17? and i thought k-pro was for the k-series. i hope ur just messing around man since your lol'ing at him. if not i will lol at you.
Go to hondata and look, you use the K-pro with a cam gear its about 1175 if i remember right.....
http://hondata.com/kpro_d17.html
and yeah the D17 is a crap motor, thats why i swapped to a k-series. I had my old d17 NA, it just sucks.
1 - 12 of 12 Posts
