Honda Civic
Using a D17 crank in a D16:
D17 Crank = 94.4 mm stroke
D17 Rods = 137mm
D17 Pistons = 27mm compression height
You need to use the D17 oil pump because the snout on the crank is much thicker then the y8 crank. No problem because it actually bolts on like a champ. Problem, there is no accommodation for a dip stick, the y8 pump has a hole in it for the dipstick the d17's pump does not.
The D17 rods are thinner at the crank end than D16 rods, so some machining may be needed depending on the rod you use.
