1 - 7 of 7 Posts
So I finally did a compression Test and found out some sad news.
Bought a comp tester at harbor freight and it was junk did not work
went to autozone got a new tester
Tested it:
cyl 1: 110psi
cyl 2: 110psi
cyl 3: 110psi
cyl 4: 120psi
Is this bad?
Massachusetts.
Could this explain why car is knocking when under WOT, also Valve cover being super pressurized causing OIL everywhere in the back of engine blowing out. also Burning LOTS of oil ringlands bad....
1 - 7 of 7 Posts
