Engine Details:
D16ZC Engine
SRP Pistons
Eagle Rods
ARP HeadStuds
ARP Rod Bolts
Cometic Head Gasket
ACT 6 Puck Clutch HD Pressure Plate
Oil Catch Can with Braided Lines
OEM Radiator
Password JDM Radiator Stary
Password JDM Valve Cover Washers
Password JDM Vtech Solenoid Cover
R-Spec strut bar
Polyethene Hard Engine Mounts
R-Spec Resorvoir covers for Power Steering / Clutch / Break Booster
Skunk2 Resorvoir Covers for Clutch and Break Cylinder
Skunk2 1.5 bar Radiator Cap
Mugen Oil Cap
Turbo Related Stuff :
Holset HX35 7 Blade
Top Mount Manifold (Heat Wrapped)
Evo 9 Intercooler
All Round Branded Silicon Couplers with SS T-bolt clamps
2.5" SS Intercooler Piping
UG Racing 38mm Wastegate
Turbosmart Manual Boost Controller
Fueling:
560cc EVO Injectors
Duetach 255 LPH Fuel Pump
Snow Performance Stage 2 Methanol Kit
Original EFI Tank
Tomei FPR
Electronics:
Neptune RTP Engine Management Tuned on 2 different Maps 93RON
DD Map low boost 10Psi, Race Map high boost 22Psi+Methanol
Prosport Boost Gauge
Auto Gauge Oil temprature
Depo Racing Oil Temprature / EGT / Water Temprature / Battery Voltage
AEM Uego Wideband
Suspension:
Tein Adjustable Coilovers (Front & Rear)
ASR Sub Brace
Beaks lower Tie Bar
Works Meister Cr01 Wheels (Work Wheels :: Products :: Meister CR-01)
Nankang NS2-R 195/55/15 Tires
Rays Lug Nuts
Others:
Custom Purple Pain tJob
Hankook Dry Battery
Civic Si Steering Wheel
Black Interior (panels etc are wrapped in high quality leather)
Razo Shift Knob
Pioneer Stereo System
Skunk2 Number plate holder
What kind of HP does it throw down, or do you have any 1/4 times?
I really like the build, the LED tails are pretty sweet.
I don't have dyno in my country, and never checked 1/4 time either. can be anything between 300whp - 400whp
See above...
Nice work! My first build included a few Evo components like yours; but then it quickly escalated beyond what the Evo injectors, intercooler, turbo would handle.
Discussion Starter · #5 ·
Evo injectors are already maxed out on 14psi :ugh:
so i cover the fueling with methanol beyond 14psi
