1 - 6 of 6 Posts
98 ek hatch
I need info on the build I'm doing. My motor is basically like the y7. The parts i have are 76mm Vitara pistons, skunk2 h-beam rods, fuel pump, stage 4 comp clutch. Can someone tell me what kind of power it would probably make and what other things I need? I had a turbo kit but got rid of it and looking to finish this up. Thanks in advance. Picture of engine attached.
so, no turbo, no injectors, no high compression.....itll make the same power as a stock y7.
besides a search?
fuel pump, injectors, ecu, tune, turbo, wastegate, blow off valve, intercooler, intercooler piping, map sensor, vacuum log, wideband o2, oil feed and drain line, mod the oil pan for return,
1 - 6 of 6 Posts
