otherwise still possibilities for my D16Z9 i wanne go NA i have skunk2 inlet manifold exhaust adjustebul cam gear feul pump ......en nnext week hondataWelcome!
It seems that the Z9 is vary similar (if not the same as) to the D16Z6. If you wish to change the pistons, you do not have to use new rods or a crankshaft. You can simply have the new pistons pressed onto your current rods.
The PM7 pistons are not a good choice, in my opinion. You will need to use the highest grade of gasoline, and tuning becomes very important because of the high probability of detonation.
Any guide to rebuilding any of the Honda 1.6L engines can guide you on how to replace your bearings, if that is what you wish to do when replacing your pistons.
