1 - 20 of 106 Posts
94 Civic Cx
Muffler wont cause this are you misfiring low rough idle any other problem you are not mentioning? Could be distributor could just need plugs wires. 100s of little thing could cause this more info would narrow this down alot
94 Civic Cx
Get a new distrubutor and fix it so you wont get anymore coolant in it. Also if the screw rounded out it can bounce around and not make contact as well which explains the redline cut
94 Civic Cx
Ok get a drill and a cutting wheel. Next loosen the cutting wheel just a little and watch how it spins. Notice how its wobbly the faster it goes. Now imagine thats your rotor button, how is it supposed to maintain spark at high rpm when it only makes contact every couple of rpm?
1 - 20 of 106 Posts
