1 - 3 of 3 Posts
ok quick run donw i got a 98 coupe and it got it with no motor and in CT it need to pass emissions so the cel must be off.
i want to put a z6 in it but the crank sensor issue
can i put a y8 oil pump with sensor and what not and still run a z6 oil pan?
is there a better way to make this happen?
i did not know where to post this and i did search but got no real good answer on it.
FF Misfit
Iirc the oil pumps aren't interchangeable. One thing you could try is taking a paper clip and using it to bypass the signal from the crank angle sensor. I use to have truck drivers to this when the coolant sensors on the trucks would go out causing the ecu to throw a cel that would shut off the truck.
All you do is take a paper clip, straighten it out, and put one end in one side of the plug and the other end in the other side then tape it into place. I'm not positive it'll work for you but for the 5 minutes it'll take to do I don't think it'll hurt to try.
1 - 3 of 3 Posts
