1 - 6 of 6 Posts
Is it possible to use a Y7 harness on a Z6 block and do I need to make any modifications on the Z6 to make this work ? I know eventually ill need to run some wires for Vtec and ICV but for know ill use the Y7 throttle body with a Y8 intake and swap the throttle bracket .The Idea is to make it backwards compatible so when the smog man here in CA comes around ( there's nothing to see here ) and revert back to Vroom Vroom 😅. Ill use switch's behind the glove box to enable and disable ODBA1 to ODBA2 Vtec and vice versa by swapping ECU's when needed 🧐.So, can we make a Z6 work on a Y7 with needed wiring an engine modifications 🤔?
Thanks, Guys !
yeah, good luck with that.
08 H-D Ultra Classic
Did you try actually clicking on the links he gave you or have you already tried reading also and that didn't fuckin' work for ya?
Sloppy Jalopy
he choo choo...
anyway ,
so if obd2 you got the man is still gonna know its a z6 .
putting an older engine in a newer chassis is illegal .
use whatever year you have obd2 to obd1 jumper harness and change ecus when the man come round..
1 - 6 of 6 Posts
