So im planning on getting some parts together and build my z6 for more boost. The car is a DD and id like to get a minimum of 250whp to 300whp (at the most)....nothing too crazy. I havent decided whether i will build the enigne myself or not...ive never built an engine before...but i really would like to. I guess im a little nervous. Either way i just wanted to find out some clearance specs that people have used for their vitara build.
Here are some specs i've found on here from other people's builds.....some specs im still unsure of. Any bit of help is greatly appreciated. Thanks.
P2W clearance: .0025" to .003"
Piston Ring End Gap: Unsure.
Main Bearing Clearance: .002"
Connecting Rod Bearing Clearance: Unsure.
Check out my sig. I would build the motor your self, you learn more, and you know whats in your motor. Just tripple check everything.
