1 - 15 of 15 Posts
eg hatch
tried to search a bit for more info but didnt find anything directly to my question
i have both a d16z6 and a d16y8 in my garage, im building an engine for 95 hatch.
are there any qualities that make either of these engines better than the other. since i will still be running an obd1 system in the car with a chipped ecu,with a completly non stock intake mani/throttle body system. most sensors that normally come into factor will not in my case.
opinions or specs would much be appreciated
Defender of the D
well right off the bat i'll tll you stock for stock the oil pump on the z6 is better than the y8's but some work to that pump can result in just as good performance.
more than just the oil pump is shitty on the Y series. but search OP damn this has been covered im not saying shit.
www.rifftrax.com
1996 Civic Ex Sedan
i'll tell you z6, but i'm not explaining why because as sick1cam said this has been covered many times.
out of the box z6 head flow better and manifold than the y8, the fuel pump is better. the compression is lower. the y8 head has smaller combustion volume thus netting increase in compression, the quench is smaller and the design helps resist detonation.
the z6 pistons have a deeper dish than the y8.
if i were you i would do the z6 its the easiest to swap into your car because of obd1. you could do z6 block, y8 pistons and y8 head,z6 intake manifold...
swap the guts out the z6 distributor and put in z6 distributor thus resulting in higher static compression than stock z6
if you use a stock z6 and a thinner headgasket of .025 will bump the cr roughly .2 but nothing noticeable.
sub-sponsor
93 civic
z6ftw y8 is the gheyness
eg hatch
hm. guess ill do the right thing and take the z6 out of my car and start building that, and slap the y8 into mine till thez6 and all parts are done.
I dont like the design of the combustion chambers of the y8 personally. So heres my thoughts
OBD1 > OBD2
Good Oil Pump > Bad Oil Pump
No timing issues > Weird Timing Issues
Open Chambered Head > Closed chambered Head
Valve cover says VTEC on some > Plain Honda Valve Cover
Nice smooth Intake Manifold design > FattyFab Design
OBD1 > OBD2
lol its whats important ey? the closed chamber head increases the compression slightly and the design helps resistance against pre detonation. maybe this compared with the intake design brings up the weird timing
eg hatch
though from what ive been reading its popular on the z6 to add a bit more metal to the z6 chamber in order to stop predetonation.
guess i got ahead of myself but im picking up my set of OE d16a1 pistons with some OE Ls rods. heard thats a common decent oem system for around 12 to 1 compression with a bit strong rod.
looking for a decent head kit for the z6, but seem to be falling short on cheap since akmee disappeared
1 - 15 of 15 Posts
