screw douchdata.get a moates device.
GO-AUTOWORKS Honda/Acura Cast Iron Turbo Manifolds B16 B18 D15 D16
Injector Nation
Injector Nation
For the mani, if I utilize the internal wastegate, I guess I can just block off the wastegate in the mani?screw douchdata.get a moates device.
Injector Nation
So I should shoot for ~500cc injectors I'm guessing? Something like these whenever they're in stock: IN575 Denso Fuel Injector Set Honda OBD0 OBD1 B18 D16 H22 F22yeah you can block off the mani hole.
those injectors will work for 200hp but are on the small side ,you will want more one day.
I easily fall into the "while im there" mentality, so I'm gonna try and stay within my goals for now, as d-series turbo may not stay in my car for the long term, maybe a few years, so I don't need to burn my wallet.I got 1000cc FIC injectors for mine at a fairly decent price. $400 or a little higher. High imp too so no resistor box needed. Why not go higher than you need Incase you want to go further in the future?
