1 - 15 of 15 Posts
How much psi can a d16z6 with stock internal hold?
I heard that most of the stock rod get miss up at about 10 psi?
Lifetime Awesome Member
'89 CRX HF
psi?
psi doesnt mean shit, its all about cfm. cfm varies depending on turbo.
do you think 10psi on a t25 is the same as 10psi on a t66?
Discussion Starter · #4 ·
well then on a stage 1 greedy kit, with a t3 turbo, can the stock internals hold up to about 12lbs?
95 civic ex coupe
like stated above psi doesnt mean shit..... its all about cfm ( how much air the turbo can move ) and horsepower.. stock z6 engines can usually hold 200-240 whp.. anything more then that is asking for trouble... and remember... ITS ALL IN THE TUNE
'89 CRX HF
I dont think it would hold up to 12lbs
yes it can. i ran 12psi on my t3 .42/.48 for over a year without a single issue. the motor still runs today
as long as you have good fuel management with a good tune, it will be fine
12psi on the stock internals you can run with any T3 .. Tuning is the key to success
95 civic ex coupe
really... so your telling me i can run 12 psi on a t3 60-1???? i dont think so
I can. But you probably can't
I know a guy ran 12psi on a GT30 on his stock D16Z6 for quite some time
On mine, I've ran up to 15psi ...
get the idea ?
greddy manifolds need about 40 hours of porting the begin to flow decent, just look at #4 exhaust port.
Don't worry about psi. They will hold 200whp safely. Pretty much anything over 210whp is getting a little brave.
1 - 15 of 15 Posts
