1 - 4 of 4 Posts
Can i put turbo manifold with turbo and downpipe from z6 to a9.???
they are custom made for my z6 and i want to sell them to a boy who has a9 ???please help.Do they fit
You should be fine as far as the manifold. i dont know about the downpipe. As far as I know all d series manifold are compatible. If I'm wrong someone correct me.
93 Legend L Coupe.
You'll want to gasket match the manifold to the ZC exhaust manifold gasket, but other than that, yes.
You have to be careful with downpipes because the ZC oil pan is different and not all headers or downpipes will swap over without something hitting.
1991 Honda CRX
Some SOHC Ram horn turbo manifold will have the pipes hitting the top of the head (by valve cover), which will cause it to not bolt up all the way. Some fit, some don't, I just bought one and it didn't fit. If it's a miniram or log then as stated above just port match.
1 - 4 of 4 Posts
