1 - 4 of 4 Posts
I did a d16z6 swap on my 89 DC civic sedan got it all wired up and noticed that now the fuel pump wont stop primming, and car won't shut off when key is turned off. Any help is greatly appreciated
You can verify the wiring by checking it to the fuses respectively, if correct check to the relays to make sure they are correct and functioning properly. A little bit of direction to start on.
1 - 4 of 4 Posts
