1 - 6 of 6 Posts
so i just did a d16 z6 swap in my car.
originally i did an mpfi swap. i got a p06 converted to vtec ecu. its chipped with chrome. i just got done doing a full motor swap etc.
the cars revs when i start it to 4 grand and bounces from 4 grand to 2 grand.
ill post video
but what are some things to check.
im almost 100% its not a vacumme leak
the coolant would make it that crazy of any idle right
the ecu does have launch control set it in.
my car is an 88 crx and doesnt have the clutch switch thing. becuase it used to be a dx auto.
sorry more details in a few..
ministry of mayhem!
93 honda integra
have you checked for vaccum leaks?
why are you so sure that it isn't related to a vaccum leak?
i have all new gaskets, i torqed everything down in sequence just becuase i wanted to be 100% sure. (intakemanifold)
im going to check vacuum again tonight but ive had vacuum leaks before but they never were 4000 rpm bouncers...thats just crazy
I got Bit by the Boost Bug
Bmw 528e
Try the brake booster vacuum,That was a mojor problem of mine in my 91 hatch and also check ur tps and the throttle body,Some will cause a high idle.
1 - 6 of 6 Posts
