1 - 11 of 11 Posts
well right now i have a d15b7 in my eg but the block is bad and i have this guy selling me a d16z6 block for $40
my questions are:
1-is it worth it?
2-Is it obd2?
3-Do i need the EK motor mounts to put it in the eg? or can i use the eg motor mounts?
4- Do i need to do anything with the wire harness or can i just put it with all the b7 parts(harness, head and motor mount)
i will put it with the b7 head or maybe with the a6 head that i have laying around.
so guys please help me before i buy it today!
ps: i searched a little
d16z6 came out of 92-95 civic and some delsol si's
EG/EJ not ek
$40 yes its worth it.
obd1
Yes motor mounts should work. may have to bolt the driveside mount to the z6, just depends, some were 2bolt and some 3 bolt i believe...but it all works out.
perfect then ill buy it since i will just have to swap blocks and thats it!!
THANKS A LOT!!!!!!!
ps: reps to you!
do you have an a6 head to? believe they are same casting, but a6 cam is slightly better, just from what I see people say on here.
yes i have a d16a6 head laying around.
this is all i have in my house:
d16a6 head and block(has 2 head studs stuck inside)
d17a1 block and head
and the d15b7 installed on the car
yeah search around the forum in the n/a section i believe or Engine building. there is tons of threads on it.
does the z6 block come with crank rods and pistons cause the crank and rods out of the b7 wont work in the z6 and the b7 pistons will stick out of the bore like .028 IIRC
1 - 11 of 11 Posts
