1 - 3 of 3 Posts
M
Hey Guys I just broke my D16A6 my question is if I am able to use same internals from the D16A6 in to the D16Z6 block? pistons, rods, cranck or what combo will work. I been told that pistons and rods will work as long as I keep the z6 crankshaft. Is this true? The only reazon I wil like to keep the internals is because the pistons and rods are fearly new ( Arias and eagle ).
O
find the journal size on the crank and match it with the z6. if there the same size the n it should work as long as the rods arnet to long.
J
crank pistons and rods are interchangable. Just make sure you save the bearings or get a fresh set
1 - 3 of 3 Posts
