ok I have a 95 d16z6 that I just rebuilt. It ran fine for a while but now it idles funny like a wrx everyone told me that it is not firing on all cylinders so I checked my firing but all of them are sparking. what could it be I need to know fast
Start the car and pull the plug wires one by one there should be a change in how the motor runs the one that does not is the problem then like the other guy said go to your plugs
I did that and number 2 and 3 cylinders are firing but not running what could that be I thank it is timing
when was the last time you changed your plug wires? they could of gone bad
Defender of the D
^^^FTW^^^ that'd be your best bet to check first. an i understand ya. its sparking but not firing. check your plugs post a pic if you can. timing could also be an issue. you got a timing light?
i am dealing with same issue i have changed spark plugs wires distributor
but only my 3rd is missing...it runs fine now.. but still a miss. so i would go through everything if i were you from cheapest to expensive till you find out what it is ...
