H
Does anyone have any pics of D16Z6 pistons? I bought a D16Z6 motor and the pistons in it are dished, but they look like stock, however theyre not flat, nor domed but dished, Can someone get me pics of their D16Z6 pistons so i can compare.
S
my d16z6 pistons had p28 stamped on em, check yours.
stock Z6 slugs, P28 casting in the RH side of pic..........
H
So how much boost do you think the stock pistons can take?
S
just make sure your setup is right and your fuel is enough, a friend of mine was boosting for about 3 or 4 months and then sold his motor, the guy who bought, tore it down and on number 2. 3 and 4 cylinders, chunks were missing out of the intake side of the pistons, wish i had pics to show, so just be careful and enjoy.....
H
thesqad127 said:
umm the pistons arent what you need to worry about
the rods will snap/bend before the pistons get warped .....
200whp-+ is what you can do safely on a stock block
The rods are eagle H beam, I was thinking suzuki vitara pistons since its a different type of cast it should hold 300WHP @ 20 PSI, because even with good fuel management I doubt that stock D16Z6 pistons will hold 300WHP
