1 - 10 of 10 Posts
No
Search!
88-95 will fit fine
all the d16 pans will bolt up to a z6 but they are NOT the same. i don't remember about the a6 pans, but the aluminum y8 pans can only be used if you also use a y8 oil pump and pick-up (and then i believe your z6 dipstick will not work)
it's much easier to just do it the right way and use a 92-95 pan on your z6
2005 Civic Si
speak the truth brotha! +rep
My Car
someone said that you could do the y8 on the z6 block, but you had drill a couple new holes for the bolt holes. Also by using the y8 pickup as well. But what i stated here is what was told to me. I guess i could put a y8 pan up to my z6 while its on the stand to see for myself.
1 - 10 of 10 Posts
