1 - 15 of 15 Posts
since im having problems with vtec, i was just gunna throw that problem out the door and use a A6 head (fully rebuilt, stock) .
what would I need to do for the A6 head to work on the z6 block?
the car is a 95 EG hatch and the block is a z6
heres the list of things i can think of so far,i just need to know from what motor to get it from :
dizzy
timing belt
spark plug wires
cam gear
ecu (maybe, I was thinking using the chipped p28 but just have him disable vtec)
allwheeldriveturboboxer
'08 Mazdaspeed3
dizzy
timing belt
spark plug wires
cam gear
probs with vtec? like what? i would not go backwards like that.
did you try a new/different solenoid? are you sure all the sliding pins are in and the rockers are to spec?
ya the tuner switched them out with a working one from another car, im pretty sure they are cause the head came off my bro's block and his vtec worked fine
but do you got the info about the things listed by chance?
thanks man
keep the VTEC head, find the problem.
To run the A6 head your gonna need to find a oil restrictor for the block.
do they have them on the A6 block?
your not talkin about turbo oil restrictor correct?
I know what I'm takling about........
Rebuilt stock A6 was able to free flow so much oil to the head, bottom end starved......
15140-PM3-000 ORIFICE ASSY., OIL PASSAGE
i have a y7 head on a d16z6 i have my d16 head in the garage LOL
u gonna need
dizzy
timing belt from a a6
oil
a6 head gasket
coolant
94 civic dx
so here are the answers to my question - of putting a b7 head on a d16z6... didn't want to hassle with vtec - or better yet... the z6 head has a broken stud in it (valve cover thing) - and I don't want to use it...otherwise fine. an oil restrictor...
what's the compression going to be?
05 Legacy GT
Hey was this thread just Hi-Jacked?
SupraRXZ, IMO you'll be happier to find out why and fix your problem then go thought the hassel of switching heads.
I understand you may have all the parts so it's almost free. But someone in your area should be able to trouble shoot and tell you what to fix. It's not like you live out in the sticks.
94 civic dx
wow...sorry bout that - i think i "unintentionally" hijack too much - just didn't want to make a new thread when this one's still ~"on topic." apologies again.
05 Legacy GT
The broken stud should be easy to have fixed or DIY. I have broken two bolts.
I got them both out without any damage.
There are a number of tools to help remove the broken bolt.
1 - 15 of 15 Posts
