1 - 6 of 6 Posts
Just swapped an A6 into my eg. The map im using has fuel and timing values from z6 maps in a p30 base code.
The car feels like dog doo. Is there a base timing difference i need to account for in the tune?
Thanks in advance. Ps, will continue my search.
check timing 1 more time
Mechanical ignition timing? Ive got it cranked full advance so it doesnt completely bog down low, but it still is horrible.
Im considering throwing timing at in on the tune but i think id rather make sense of what's going on lol
Run a stock B7 ECU and be done....but check mechanical timing (7 o'clock) of the cam gear first.
Discussion Starter · #5 ·
I may do just that but I think Id rather have the ability to make adjustments. Plus then Id have to do some rewiring if i revert to an unmodified ecu. Minor, but more work nonetheless.
After work ill be checking mechanical timing. Thanks bone, always helping out.
1 - 6 of 6 Posts
