1 - 7 of 7 Posts
EG hatchback
I got my motor put together but one thing j got this Rc injectors for the stock manifold with aem fuel rail. Had oem fuel rail washers on first use oem seals that for stock injectors put it on the injectors do not fit all the way down look like its floating and the washer has a gap.
Then had another set from an oem replacement seal bottom o ring. that is like 1/2 size smaller than stock oem injectors o ring. feels little lower When I install the 1/2 size smaller o rings.
Is this how when I install Rc injectors.
Should I b ok?
Use the oem seals or the 1/2 size smaller seals idk had two size injectors in a oem replacement I've bought.
Also the 1/2 size smaller I ring still has a gap see the gap.
Washers?
Idk what's correct if I install these injectors
Im running RC's on stock fanimould and AEM rail. The bottoms of mine seat the same as yours but the tops do sit flush.
My RC's cam with seals, so I just used them. Although I pinched one of the top seals the other day and replaced it with a random A/C Oring from Halfords (motor spares place here in the UK). I just found one that fitted snug and it hasnt leaked yet.
1 - 7 of 7 Posts
