1 - 6 of 6 Posts
C
D16z6 give me info (PLEASE)
I have a 88 civic hatchback Iam about to install a D16z6
from a 95 del sol si. what modifcation am I looking at such as
motor mounts do I use my 88 or find 1995 ,what wire harness
what is the best transmission I will run boost possible Nos
I have car gutted for paint every thing is out and I do mean everything.
any info on what Iam getting into would help I know the car inside and out
Ive built 2 previouly but never did motor swap.
2011 pilot
depending on weather the car is dx or si yo will need to do a obd1 conversion and get a p28....motor will bolt up to your stock tranny....get an si tranny if you dont got one....and that pretty much it....im sure there is minor details i left out
D-Series Destruction Master
Use an 89-91 SI transmission (get a new clutch, 88 clutch doesn't work with 89+ transmissions)
use your stock motor mounts from your 88 motor.
do a basic dpfi to mpfi conversion + an obd0 to obd1 conversion
C
this is the same problem i have.the changed dpfi to mpfi still dont match the plugs of the obdo from the ecu and under dash. I have the conversion harness and still no luck?
Wow, first thing to do.
Register a new username, your user name makes me want to kill myself, my gf and our cat.
Second off...wow...
www.rywire.com since you cant figure it out by using search here.
1 - 6 of 6 Posts
