1 - 7 of 7 Posts
Civic coupe 99ek
Allright first off thanks in advance really appreciate it i did a d16z6 swap into my 99 civic im getting fuel just no spark i changed main relay,dizzy,got ecu jumper harness and dizzy jumper harness also checked grounds and wires so im getting power to the dizzy just i have no spark what could this be also no codes are neing thrown only two code 14 and 70
Is the distributor new? If not could be the coil or igniter. The Ecu jumper or distributor adapter harness could be bad.
How are you testing for spark?
coil, igniter, rotor, cap, wires.....
1 - 7 of 7 Posts
