1 - 20 of 31 Posts
First engine build ever at 19yrs yes ima young buck but tryin too do it the right way first not blow it up in 2mins
MY HP RANGE in the 300-360HP range
so im starting with a D16Z6:
im having the block bored .20 over
i bought FRESH Wiseco pistons 75.5mm
nd Eagle rods
i have standard size acl racing bearings full kit
stock crank i read that they come forge just getting it micro polish nd balance
a manual grindle with arp bolts
thats the bottom end total bout 900$
TOP END i was goin too get all Bisi valve train with super tech vales maybe .50 over and a 2.4 cam
need advice on should i get pnp done or not
450cc injectors
p28 ecu chipped
and still dont kno what turbo set-up im gettin yet
all this is goin into in ef hatch 91'
just tell me what im missing im doin research as im puttin this up:3dtard:
Certified O.G.
A Shitbox
You're missing the turbo stuff to hit that HP goal of yours.
Also, I'm not to injector savvy, but I think 350+ is pushing 450cc injectors.
Edit: To save money, you don't really need to build the head as i'm near positive a stock head will hold 300+.
My car...
Stock head can certainly do 300hp (400hp has been done), but port clean up + cam can certainly widen the powerband.
OP, what turbo are you looking at using?
I have similar goals, and I'm leaning towards a T3/T04E 57 Trim (.63a/r)..
Which is about $575 from Spoolin Performance, should fit into your budget/powergoals nicely.
PS: You spelled FROSTY wrong. It's spelled FROSTHY.
88 hatch
Id prolly go with a 550cc injector. While a cam or port may not be necessary it will make your power goals easier to hit and as already said will give you a much wider power band. Less lag more mid and top end power the head is where you make the power in all engines.
88 hatch
What brand turbo you thinking? Im not a fan of ebay turbos. They are hit and miss it seems and flow less than their quality counterparts.
Certified O.G.
A Shitbox
so ill be lookin at 1000-1500$ for the kit right
Go-Autoworks street kit can be had for a bit more than what you listed, but is made up of the highest quality parts. Shoot Greg a PM and talk to him about some options.
Certified O.G.
A Shitbox
yeah nd it wont hit 400hp for sure
Open deck block? youll put alot of stress on it at 400 and after that you asking for it
Honestly, sounds like you both of you need to research high HP builds. D series blocks have been proven time and time again to hold 400 with no sleeving work done.
My car...
600whp+ has been done on stock sleeves/Vitara's....
Whats an open deck block? No block guard?
Yes. "closed deck" with D16's blocks would either be:
Cement filled, Block Guard, Sleeved.
But wouldn't be Closed Deck in the same way as a true closed deck.
oh i kno they only can hold 400 but ive seen dangrous builds thats higher but unsafe
400whp has been done on pump gas.... On a T3/T04E 57 Trim too.
And OP doesn't mention what turbo he plans to run either.
D16 vitara build on pump gas - 420whp/319tq - onecamonly.com
400whp on stock sleeve D16's is nothing new.
Quite a few engines have lasted quite a while too.
If you do a shitty build, shitty maintnance, or have a shitty tune, blowing stuff up is a given.
Certified O.G.
A Shitbox
For your 300-360 hp goal, stock sleeves will be fine.
1 - 20 of 31 Posts
