on a d16z6 motor is .050 over size piston to much for boost application...
if so wat is my best size..oh yeah i dont want to sleeve,.thks
.5mm FTWare you sure you mean .050 oversized and not .5mm oversized?
yes yes if only i could have the bore to stroke ratio of a b18.If I sleeve a motor it will be around 78mm but with a shorter stroke![]()
LOL fixed it for ya"Thers no replacement for displacement as long as the displacement doesnt harm RPM." enough said
