1 - 4 of 4 Posts
Hi I need to know if a d16z6 dipstick will fit same specs with a d15z1 dipstick block? I don't have a d15z1 dipstick....
are these same?
put in the effort and check parts numbers?
Parts numbers are different for EUDM models: 15650-P07-000 for the D15Z1 and 15650-P03-00 for the D16Z6 engine. Don't know if it might be just a little different handle or the max/min indicator holes are set differently or if one is just longer/shorter than the other.. the tube/pipe in which you put the dipstick has the same parts number.
1 - 4 of 4 Posts
