1 - 3 of 3 Posts
Is it possible to use a d16y8 crank pulley on a d16z6? If not, is there a way to tell the difference between a z6 pulley from a y8? I have a d16z6 block mated to a d16y8 head if that makes a difference. thanks in advance
y8 crank pulleys will have dampers whereas the Z6 ones wont afaik
y8 has 12 degree base timing ; Z6 have 16*...now im not sure if each of those different pulleys are indexed accordingly.
hey bone, still awake? care to throw in what you know about this?
Yes, they are indexed differently. The red line on the pulley indicates base timing which, as you mentioned, differs between the y8 and z6.
1 - 3 of 3 Posts
