1 - 9 of 9 Posts
Hello everybody quick question. does the d16z6 crankshaft come in 2 different sizes???Remanufactured Crankshaft Kits
inthe link above it says that the neck sizes are different need to kno soon becuz im about to go buy one in a few hours so any help is welcomed.I just bought a d16z6 the head code [po8-5] says its off a 94 if that helps. thanks
'97 crv
Is the neck the snout? Possibly just 2 different crank pulley sizes?
'97 crv
Well if it is the snout then you can get which ever one and then get the crank pulley to match, just a thought.
thanks guys. dont have the crankshaft to measure bought the motor for 80 but didnt come with the crankshaft. i have the pulley how should i measure that to determine if i use that one or the other size??
ej1
Measure the inside of the crank pulley with calipers if you can. As stated above you want the .944" snout most likely.
1 - 9 of 9 Posts
