i read so many turbo and n/a threads on this site that i decided to start my own build thread. what im looking for is insight from people that have been thru it with a turbo build. ive built a all motor z6 and after driving it for a while i found out that its really not that fast(162whp). the car this motor is in is a 89 civic hatch (ef). i mean i beat b16's, k20's, a few gsr's but that doesnt doesnt mean anything when i roll up my homies 350z or the modded wrx's around here. i fell like i need more hp, so turbo is the way to go. but i know very little about turbos as a whole so i figured i would show you what a have and give you the results i want to see and if i have any problems or if you have any advice you could help me. thats what fourms are all about right???
ok so heres what i have
89 hatch
si trans
z6 head/block
comp cam 59300
ti springs and retainers
ported/polished head
port matched skunk2 intake manifold
port matched skunk2 68mm throttle body
thermo tb and im spacer
3 bar map sensor
siemens 750cc injectors
walbro 255lph fuel pump
ac autotechnic fpr
honda z6 head gasket
arp head studs
arp rod bolts
aries 9:1 pistons
eagle h beam rods
acl race bearings
block bored 10 over to match piston rings
crank knife edged and cut 10 under to match bearings
oil pan fitted with an steel braided return line
new chinese t3/4 turbo rebuilt w/new gasket and seals so it wont smoke
huge intercooler, very big for my car but it should look great when on
real greddy bov
cheap tial look-a-like wastegate
standard ebay boost controler
obx mini ram turbo manifold
stage 5 clutch kit (holds 540 ft. lbs) with 8lb flywheel (i know its over kill)
exhaust cut out with 2 1/2 piping stright back
turbo piping and other accessories.
now that you know what i have here are my goals:
* i want to boost 22psi on this motor. i have heard that you can boost
up to 27 without sleeving it.
* and my horsepower goal is at least 330whp
now are my goals reasonable. what areas have i overlooked and what do i need to watch out for.
this will be driven on the street 2 days a week or so and taken to the track every chance i can. i have a very very good tuner that is going to tune the car so i dont need help with that.
89 hatch
si trans
z6 head/block
comp cam 59300
3 bar map sensor
ac autotechnic fpr
arp head studs
arp rod bolts
aries 9:1 pistons
eagle h beam rods
acl race bearings
real greddy bov
