95 civic coupe
I'm going 11mm custom studs so i won't be needing these anymore It's been torqued about 4 times so it's not the best looking cosmetically wise, but none are stretched and are still in good condition and will come complete with nuts and washers. I would hate to see it sit so I am posting it here to see if anyone could find use for it.
$60 shipped sounds fair? I'll be posting it on my local FB group but thought I'd share it here as well. Thanks for looking!
Regards
Jun
Reactions: slo_eg8
hey Jun, I would only need to get one other stud if using on a d16y7 correct?
95 civic coupe
Discussion Starter · #4 ·
I have another set of d16z6 headstuds without the washer and nuts I'd you just need one.
Will consider.
Gotta get a quote from the machine shop here in the next day or two on a cylinder head refresh. Pretty sure I have 3 very leaky exhaust seats and at least a couple of bad guides considering how much oil I loose on the highway, even with replaced OEM stem seals
Tape-R taper/driver
EC3, ED8, ED9, EE5
Put me in line.
95 civic coupe
Discussion Starter · #7 ·
It's still available. Bump
del Sol si '94
Ill take them. Sending pm
