1 - 7 of 7 Posts
I understand just wondering ball park numbers I'm tuned on crome pro using 550 cc injectors fic .75 retard timing per psi of boost
94 Integra
What kind of power can a 13 g make at 8 psi on stock d16z6
Why stop at 8psi? That turbo has similar comp flow as a 50trim T3, but a smaller turbine IIRC. When I tried out a 50trim T3 on my piston/rod D16Z6 it made 160/140whp 6psi with stock exhaust. Get a 4bar MAP sensor and push that puppy to 15psi for 180-200whp.
ej8
Datalog it and run it through VD (virtal dyno program)
It will make a est dyno sheet for you.
Or calc your injector max hp output, then find out your duty cycle at max boost n redline. Then do some math and it woll give your a ballpark of your power output.
this
1 - 7 of 7 Posts
