1 - 6 of 6 Posts
Hello!
I but Hard engine mouting.
But still gears comes out.
Espessaly when I drive Hard track and bumpy road. 2 and 3 and 4 gears comes out.
I thnik the problems is the gear forks, but maybe smarter guy nows better whats wrong.
Tnx.
Wheel Vehicle Land vehicle Car Tire
Automotive tire Motor vehicle Automotive exterior Wood Bumper
Gear Gas Art Metal Sculpture
Grab a wire feeler gauge set and check the clearance between the forks and the slider grooves they sit in, im not sure what the spec on the L3 should be, but there shouldn't be much play. if you can find a good machine shop they can fill weld and regrind the forks back to spec, or you can dig around for a replacement set. Other issues you might want to look at are the shift arm being worn out/bent, and the rods themselves wearing the clutch side case out.
Discussion Starter · #4 ·
Okey. I check when I finished two asphalt race.
When I change gear under the car with hands, everything goes in and out very good. Maybe the gear shifter is not good for me. But I rember when I drive OEM shifter then two tree times for a year comes out second gear when rpm was 7000-8000 and again bumpy road.
Gas Household hardware Machine Auto part Cylinder
1 - 6 of 6 Posts
