1 - 18 of 18 Posts
G
People, what he F%·$??? Ok look at my engine code. I dont live in the U.S. i live in Venezuela. But anyways i cant find info about the specs of my motor. Any suggestions??? I know its non vtec, sohc 1.6 civic 98 ex. Dont know any more about it. Help! :?: :?: :?: :? :? :? I cant go on with my turbo installation because i have NO idea about the specs.[/b]
G
Discussion Starter · #5 ·
hehe if i could read. yes ive seen that yellow turbo civic here in caracas but i tough it was imported from the U.S thats what ive heard. anyways ill try to contact the owner its no biggie. thanks anyways!
G
Discussion Starter · #7 ·
Finally found my engine specs!:
Compression Ratio: 9,2:1
Engine: 1.6L SOHC
Vtec: No
Weight: 995 Kg.
Horses: 100whp
Thats about it
· Banned
D16Y9
equal to D16Y4
non vtec
Found in:
1996-2000 Honda Ballade, Honda Civic in South Africa and Venezuela
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
(79.0 kW, 107 ps) @ 5900 rpm (At 110 hp (82 kW) @ 5500 rpm)
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 4000 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD2A MPFI
Redline : 7200 rpm
Rev-limiter: 7411 rpm
Head Code : P2A-9
Piston Code : P2K
ECU Code : P2K 2 Connectors
The D16Y9 in South Africa has different power figures:
Power: 89Kw (119 hp) @6400rpm
Torque: 146Nm (108 lbf-ft) @5500rpm
Information found in April 1998 CAR Magazine(SA)
source: wikipedia
HONDA
yeah its like the D16a7 its the same as the d16a6 but no cat.
could it not be the same with d16y7 and 9?
but yeah the d16y9 is a local motor here. its ODB2a. they ok seen some big power out of one. 230wkw. not stock. but thats what they can do.
EJ6
Zombie threadssss.... Woogie Boogie!!!
1 - 18 of 18 Posts
