1 - 12 of 12 Posts
hey i have a 97 d16y8 and i have i/h/e and want to get it port and polished get msd a cam and intake manifold and my question is has anyone added this and i want to know if its worth the money and will it be hig 14's thanks!!!!!
no it wont be high 14s...add a fifty shot you will be deep into the fourteens with a ported head/ IM, msd and cam
Stage 1 = waste of money. Get atleast stage 2, or even 3 because of porting.
MSD ignition = waste of money. OEM with good, fresh wires is good even for 600hp turbo engine..
Rushi if i do i/h/e/mild pnp and im would you recommend me going cower stage 3 or should i go stage 2
I made itto the 15's with boltons in my 00 ex :) lol.
I would vote 2 for the MPG factor...it will suffer A LOT with a stg3.
How well will a sohc run with a crower 3 and stock compression, anyone know. I know most of these have motors have 9/?/? compression. I just got my head ported and lost almost 9.5hp. I called brian Crower and he told me you should have compression to run a stage 3. So i am also looking into a larger cam, although i am not 100% sure that is my problem
y8 stock has a 9.6:1 cr ratio. a 2 layer gasket will bump that to just shy of 10:1
the stage 3 is meant for high CR but with a good tune it will work just fin on a stock cr y8
1 - 12 of 12 Posts
