1 - 4 of 4 Posts
I know this build has been done many times. because of this, I would like some input on what parts and specs I should be aiming for in this build. I am planning on rebuilding this motor from the ground up. I have little experience and wanted some advice. I would like to push 500 - 600 hp
thank you all
Sloppy Jalopy
whats the problem? I vd'd lots of self builds that have been 500+crank horse power ..
I'm more concerned about this..
op why ?
unless this is a drag only or 3-4 pulls then shut her down there is no point it won't be reliable at all..
it will push coolant no matter what ..
because the search bar is broken?
if only there was a place that had build threads and what they did and used.
pay someone to do it for you
buy a k20
thank you all
1 - 4 of 4 Posts
