1 - 4 of 4 Posts
d16y8 thermostat housing points up???? does b7?
I just put a b7 in my 89 DX. The thermoswitch is on the back on the block like it is on EF's. I happen to have a y8 thermostat housing with thermoswitch.Everything bolts up fine. The problem is the that the nipple on the housing, where you connect the lower rad. hose is pointing up at like a 45 degress angle. That can't be good for flow????
If someone with a b7 (92-95 DX) could tell if the thermostat housing is facing up or not. so I know if I need to source another housing or not. if the b7's is the same I just leave it I guess. Also it's threaded for the thermoswitch right?? MUCHO REP for anybody that can answer.
1995 Civic EX Coupe
yea mine points up just like that. but how is your b7 switch on the back? I just extended my wires over by the thermostat and plugged it in.
Hmm, that seems like it would restrict flow. Well, that's something I don't have get (Man, I've been haviong get all kind of random shit trying to put a b7 in my EF). It's not on the back. I have a y8 thermo housing tapped for the thermoswitch. The EF one doesn't fit in the housing, it to long.
FAMILY MEMBER #316
i think its to eliminate a lot of air bubbles that other manufacturers' engines can be prone to after a coolant change/flush.
1 - 4 of 4 Posts
