1 - 18 of 18 Posts
Sloppy Jalopy
so I am supposed to tune this shit for a guy but the car didn't want .
warmed up the car A/F at 14 ,timing locked 12deg in crome gold map,turn off car go get timing light ,hook up timing light start car back up after 1 minute it started making this sound...
http://youtu.be/nGaQxT6DSvo
Sloppy Jalopy
haha ,, maybe
what does it sound like to you , why you say valve train ,it does sound like it ..
so had the valve cover off, looked normal , retainers all the same height ,
changed out rocker ass and still same sound .
dropped pan ,no sparkle ,no excess play on rods .
Though it was an exhaust leak but don't see any...
maybe the "guy" didn't notch the block enough ?
but it ran fine moments before ...
Sloppy Jalopy
Discussion Starter · #8 · (Edited)
Old school screwdriver listening trick.
Did the knocking/ticking increase along with the rpms?
yeah I used my stethoscope to listen around,,,
So the head is off now ,,,
It turns out when the guy put this block together he lost a chainsaw file into the cylinder when checking for TDC :yes: and only fished out part of it..
so yeah toaster wins with she dead :biggrin:
pics of carnage
I nearly choked to death on trail mix when I read this because I was laughing so hard.....
Reactions: slo_eg8
Sloppy Jalopy
Discussion Starter · #13 ·
Damn. That's unfortunate! But really?! Wouldn't you make sure you got the whole file out before running your freshly built engine lol
when you say you you should really be saying the guy because if you are saying you then it sounds like you are saying you as in me inturn would make me the guy which would be wrong.
but to to answer your question ,I don't put anything down the spark plug tubes except spark plugs.
never understood that concept of putting things in something that wasn't meant to have things put in there:8:
in for pics
Reactions: robgoof
Sloppy Jalopy
Discussion Starter · #18 · (Edited)
so here is the pics ....
wasn't a ufo this time...
anywuay scars look deep hope he atleast changes the piston and buffs out his head ,,,
don't like the look of some scratch's going on over there either ,,oh welll...
shakes fist
1 - 18 of 18 Posts
