D16y8 swap to 93 eg si need to set up Vtec
ok well i swap a 98 hx on my 93 si but now my car is running with a p05 ecu cuz of the obd1 harness and the swap was of obd2 so if i buy the conversion kit to make my p05 non-vtec ecu into a vtec..would it work ok with the motor cuz i know that the hx (vtec-e) is different from the ex or si the vtec in a hx kicks in at 2500 to 2700 RPM and the regular vetc of ex and si kicks at 4000 to 4500 RPM would it matter ? if so any suggestions ..?
thansk..
thansk..
