1 - 7 of 7 Posts
have a 2000 civic coupe with a d16y8 that i done a 5 speed swap on. is there anyway to chip up the factory obd II computer? would like to see about getting the vtec to come in at a little lower rpm. also, what is the max rpm that i should turn this motor? motor is all stock but would like to get just a little bit more out of it na.
how much effort have you put into looking for the information on "chipping an obd-2b ecu"?
i did serch it and found some of my info but also has some other question in that post. that is the reason i posted it in the forum.
so, then you found out how to chip an obd-2b ecu......
'93 / '95 Del Sol Si - '95 DX Coupe - '00 Accord EX F23 Manual
That's my new signature.
I have found the best way to chip an OBD2 is to buy an OBD2 to OBD1 harness adapter and then slap the appropriate ECU on the end of it.
Then I usually take the OBD2 ECU and sell it on eBay and buy a taco or an oil filler cap with the money.
Seriously...that's my new signature.
<3
1 - 7 of 7 Posts
