1 - 6 of 6 Posts
99 Civic Ex
I spun bearings in 2 Y8 motors. After some investigating i was told that at high rpm's the oil pump shaft can slip causing oil pressure to fall. Does anyone else know of this or has proof of this happening? If so what was done to fix it?
97 honda coupe
not possible. the main reason for these issues is because of a shitty crankshaft design and oil pump that flows nothing.
99 Civic Ex
Is there anything i can do to fix this? I'm in the middle of rebuilding another motor right now. I have a budget of like $700 where should i spend money so this doesn't happen again?
97 honda coupe
replace the oil pump and get a z6 crankshaft along with brand new bearings on the bottom end.
bearings= about 60$
oil pump= 80-120$
crank= about 120$
so for about 400 you can have your build up and going again.
98 Civic EX
or you could just port and shimmy the oil pump...look around for the write ups on this, there are all over the place
1 - 6 of 6 Posts
