1 - 6 of 6 Posts
Hey I have a D16Y8 with a K&N cold air intake, Megan headers, Skunk2 catback, and a Bisimoto stage 2 cam. I just bought a 70mm skunk2 alpha Throttle body, and a skunk2 pro series intake manifold.
My question now is do i have to get it tuned? Bigger Injectors? Will it be ok with the stock settings/injectors?
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
Stock injectors should be fine. Yes you need to get it tuned, you shouldnt have had to ask that. And use no bigger then a 60mm tb on a na dseries. A 70mm is retarded man.
Im building it for a turbo so the 70mm is going to have to do for now.
Installed I/M and tb yesterday and it idles at 600rpms as long as im at a complete stop, but if i just coast in Neutral the rpms are at 2000 any solution?
1 - 6 of 6 Posts
