1 - 4 of 4 Posts
Hey guys and possilbly girls, does and one know how the d16y8 intake manifold, and exhaust manifold will effact the cars HP and TRQ ? sny info eill be helpful.
Also its in a 94 civic hatch with the stock p05 (cx) ecu will this al work ok together ? and what injectors should I use ?
Thanks in advance
ex-g (canadian)
no one has a dyno in their head, it's probably going to give you some power but how much? nobody knows exactly
use the same injector you already have
you should swap a 16valve head... i'm sur you can find one for less than 25$
I feel the difference, alittle slower off the line but when you get to cruising alot more responsive. I also went with a 99 ex header, the 96-97 had a cast piece. I'm missing the cat so it's straight piping right now.
1 - 4 of 4 Posts
