1 - 9 of 9 Posts
i have a 93' ex like stated and i was wondering if a d16y8 will bolt right up without any wiring issues or what??
THANKS
EX coupe
i wouldnt see why not....computer is different, Dizzy wiring etc not to sure bout...but...shouldnt be hard at all....call around, ask for more help, or go to your local trust worthy mechanic...heh..
quick question.....where are you getting this conversion to obd-1?
the car is already obd-1...i'm not changing the head i'm just using a diff. block...i won't have to convert any computer
98 Civic EX
if you use the Y8 block with the Z6 head & intake manifold and all the Z6 sensors then you won't have any problems. i just did this but i used the complete Y8 motor and put the Z6 intake on it using all my original sensors. I used a 92-95 D15B7 distributor and everything is working great.
D-Series Post Be-itch... gimme gimme gimme
Than why would there be any issues?? If you use all the sensors from the chassis, and the head from the chassis, there should be no issue.
alright...perfect one more question
anybody know where to find a y8 shortblock i've tried ebay and my budget is runnin around $500
thanks everyone
1 - 9 of 9 Posts
