1 - 4 of 4 Posts
E
good day guys..............any pros and cons?????? tnx...
Existing Mods;
1. I/H/E
2. lighten fly
3. s20 tranny
*planning to get a zex 105300 cams next month........any problem with dis cam if i milled my y8 head????? tnx guys
Existing Mods;
1. I/H/E
2. lighten fly
3. s20 tranny
You can just remove the middle layer from your y8 head gasket to increase compression. A dude on h-t is running a delta 272, 40 thou or 60 thou milled and the y8 2 layer head gasket. You should be fine with a zex cam and milling the head. You will need a cam gear.
1 - 4 of 4 Posts
